Pole-zero compensation in HSPICE
gilbertomaldito
Full Member level 3
Hi, how will I know the correct Rc and Cc values for this circuit in HSPICE?
thanks
--gilbert
by the way, this one is an LVDS driver circuit...
Do you what Hspice to find the correct value for Rc and Cc then only way i can think of it is, using optimization. Look into the SA manual for usage. This is some wht automatic.
other way is to do data sweep different set of values for u r Rc and Cc. Here you have to check the results u r self.
Upto my understanding this Rc and Cc has to be decided by you based on U r design requirement and I don't think it will be gud to find the values by trails.
Hope this helps.
Thanks,
Rc,Cc here is to compensate the CMFB loop. To get the correct values of them, you have to be aware of GBW of CMFB amplifier, GBW of the main amplifier, and the relationship of them.
