PNP help - Original burns out in 3 months
ken2028
Newbie level 3
PNP help
I figured out the pinouts.. Can someone point to me a better substitute.
The originals work fine after 3 months then it burns out again.
Maybe there is a better one out there?
PNP
1- Emitter
2- Base
3- Collector
hFE=292
Uf= 765m
That information doesn't really help. Do you know it's actual part number or alternatively, can you show the schematic it is used in.
Brian.
Try a heftier PNP like a 2N2905 in a TO-5 metal casing, for proviinng at least twice or triple the originals power spec.
The original is only borderline overloaded if its handling 3 months of use , if being in use daily ?
73's de Edd
PNP help
PNP
1- Emitter
2- Base
3- Collector
hFE=292
Uf= 765m
Describe device and where transistor is used. Maybe you should look elsewhere for source of problem.
Best regards,
Peter
