Alex329
Junior Member level 3
I would like to know if I use PML should it give the same gain results as when we use the radiation boundaries?
Also, when I apply the PML on all the surfaces of the airbox of my antenna, I get the following mistake after validation
%1 '%2':: The material of the PML base object cannot be anisotropic
I would like to know why do I get that mistake? Is it beacuse the antenna is anisotropic? Should I apply the PML on all the airbox faces? What is the proper way to assign the PML in that case ?
Thank you
Thank you
