pratyush23
Newbie level 3
I m trying to work on a digital integrator..i have the verilog code of the integrator as follows...
module dig_int(output reg y, input x,clock);
reg z='b0;
always @(x,z)
y=x+z;
always @(posedge clock)
z<=y;
endmodule
i used x-hdl to convert it to a vhdl equivalent..and the code generated was as follows...
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY dig_int IS
PORT (
y : OUT STD_LOGIC;
x : IN STD_LOGIC;
clock : IN STD_LOGIC
END dig_int;
ARCHITECTURE trans OF dig_int IS
SIGNAL z : STD_LOGIC := '0';
SIGNAL y_xhdl0 : STD_LOGIC;
BEGIN
y <= y_xhdl0;
PROCESS (x, z)
BEGIN
y_xhdl0 <= x + z;
END PROCESS;
PROCESS (clock)
BEGIN
IF (clock'EVENT AND clock = '1') THEN
z <= y_xhdl0;
END IF;
END PROCESS;
END trans;
on synthesis of the above vhdl code, there is an error in the line
y_xhd10 <= x + z;
please suggest as to how to rectify the above problem..or any other prb so that the code can be run error-free
thanks.
reg z='b0;
always @(x,z)
y=x+z;
z<=y;
endmodule
LIBRARY ieee;
ENTITY dig_int IS
PORT (
y : OUT STD_LOGIC;
x : IN STD_LOGIC;
END dig_int;
BEGIN
y <= y_xhdl0;
PROCESS (x, z)
BEGIN
y_xhdl0 <= x + z;
END PROCESS;
PROCESS (clock)
BEGIN
z <= y_xhdl0;
END IF;
END PROCESS;
END trans;
y_xhd10 <= x + z;
thanks.
