melkord
Full Member level 3
I would like to plot my output using OCEAN in Assembler/Explorer.
Here is one of the outputs from the generated OCEAN script.
After executing the script using load(), nothing is plotted.
What did I miss?
Previously, I used ADEL to generate plots when performing gm/id characterization.
What I did was defining traces and used ocnYvsYplot() to plot.
I tried similar thing in my current OCEAN script and wrote something like below lines, but still it does not plot.
ocnxlOutputExpr( "swapSweep((cross(VT(\"/VOUT_INV\") 0.6 1 \"falling\" nil nil nil) - cross(VT(\"/VOUT_INV\") 0.6 1 \"rising\" nil nil nil)) \"N\")" ?name "across_TOT" ?plot t ?evalType 'maa)
What did I miss?
VOUT_INV = v("/VOUT_INV" ?result "tran")
newWindow()
plot(VOUT_INV)
