Please suggest any solution for Electronic Noise in BUS
Smart
Member level 4
Who has experience in electronic noise in the bus?
We designed an electronic device in the bus, but electronic noise in the DC voltage, in the bus has bad effect on our devices.
Regards
what is your question?!
Re: Electronic Noise in BUS
Would you please let me know the noise band in the transportation bus vehicle?
We used DC-DC converter, but it still can not protect the electronic boards from the noise.
The timekeeper loose data because of negative overshoot. The board make error because of noise. Max232 burn too much.
what type of noise you are talking about? what is that noise which will burn ics? i am afraid you have a short circuit somewhere. you have to give more info
