Maya Laxman Sawant
Newbie level 5
programming a rake receiver
hello
can u plz send me a block that can help me to write program.....
RAKE receiver recognized that useful information about the transmitted signal is contained in the multipath component of the received signal. Thus, taking the view point that multipath may be approximated as a linear combination of differently delayed echoes, the RAKE receiver seeks to combat the effect of multipath by using a correlation method to detect the echo signals individually and then adding them algebraically. In this way, intersymbol interference due to multipath is dealt with by reinserting different delays into the detected echoes so that they perform a constructive rather then distractive role.
1. An appropriate delay is introduced into each correlator output so that the phase angles of the correlator outputs are in agreement with each other.
2. The correlator outputs are weighted so that the correlators responding to strong paths in the multipath environment have their contributions accentuated, while the correlators not synchronizing with any significant path are correspondingly suppressed.
hello
