Tiwana6330
Member level 1
Hello
I have an old power supply circuit which I am trying to repair/ replace. It has an Op Amp F007C. I have tried to Google F007c but I am unable to get it's datasheet. Due to this I cannot understand I cannot check the board/ unable to figure out what voltage output the supply should give. However, I came across this "temperature compensation positive/passive symmetric stable power supply" schematic.
I am hoping that by understanding how F007C works in this circuit, I will understand the voltage rating etc of the powersupply at hand and will be able to make a new powersupply of required specs. So, my questions are as under
1) Has anyone got datasheet for F007C? OR
2) Can anyone explain the function of F007C so that I can make a new powersupply? OR
3) Any equivalent/ crossreference part?
Many thanks for your help
I have found that F007C is a Triode
http://horu2010.en.seekic.com/product/discrete_semiconductor_products/F007C_The_amplifier_F007C.html
Would a simple 741 work as a replacement?
