brownt
Member level 3
Why is it that when the frequency of of musical note is changed by electronic methods, it doesn't sound good? The further the note is changed the worse it sounds. Changes in lower notes are better than changes in higher notes.
For example, playing a note on a guitar sounds ok, and playing one octave up sounds ok, but if the first note is pitch shifted an octave electronically using an effects unit, although it is up an octave it sounds different, squeaking, a bit distorted and not good. Why is that?
