Pin configuration for glass breaking sensor
hez_91
Newbie level 5
Singapore
Hi
I am working on a anti house breaking system project and i just purchased a glass breaking sensor. However, I am not sure how to configure the pins of the glass breaking sensor.
It has +, -, Relay NC, RelayCOM and 2 anti-tamper output pins.
Here is the datasheet.
I have no problems with the +, - and output pins but a little confused with the relay pins.
Can anyone help me with that?
Have a look at the attached picture ..
When sensor is trigged the active path goes via RLY(Comm) and RLY(NO), so the loop RLY(COmm)-RLY(N.C) is open..
IanP
:D
    hez_91
Thanks for the help.
My aim is to get a logic "1" when the sensor detects a glass break for microcontroller program to trigger a series of events.
I have connected
+ to Vcc
- to Ground.
Where should I connect the rest of the pins to?
Connect RLY[Comm] to GND ..
Connect a pullup resistor to +5V and RLY[N.C]
When the sensor is not activated the RLY pulls the signal down to GND – logic ‘0’ ..
When the sensor is activated, the RLY's contact is open and the pull-up resistor pulls the voltage up to 5V – logic ‘1’ ..
See attached picture ..
IanP
:D
    hez_91
