SAWULA
Newbie level 6
I am trying to build a humidity sonsor using HS1101 and 555 timer. The humidity is calculated based on the freuency. And I found several coding example and combiled them to find the frequency first using Mikroc pro. But when I run that in the Proteus nothing displays on the virtual terminal. But the serial communication is working. The entire codings are posted below.
Can any one Please help me! It's an urgent matter!
Thank you
char error;
void Comm_Write(unsigned char *s);
void interrupt(void);
void Long2str(void);
void main( void)
ADCON1 |= 0x0f; // disable analog inputs
error = Soft_UART_Init(&PORTA, 4, 3, 9600, 0); // Initialize Soft UART at 9600 bps rx tx
TRISB.B2 = 1 ; //RB2 interrupt pin as input
T0CON = 11001000;
INTCON2 |= 10010000; //interrupt on rising edge
Delay_ms(2000);
Comm_Write("Serial OK"); //Check serial
do
cntr = 0 ; // clear counters
ovrflw = 0 ; // T0IF, INTF and GIE enabled
INTCON = 10100000 ; // T0IF, INTF and GIE enabled
while(ovrflw < 39063) ; // wait 1 second : 39062.5 = 40 000 000 / 4 / 256, rounded up 40MHz crystal
INTCON.GIE = 0 ; // stop all interrupts
Long2Str() ;
Comm_Write(str) ; // write string
} while( 1);
if(INTCON3.INT2IF)
{ /* * RB2 interrupt */
cntr++ ; // inc. transition counter
INTCON3.INT2IF = 0 ; // clear interrupt flag to enable next call
else if(INTCON.TMR0IF)
{ /** TIMER 0 overflow */
ovrflw++ ; // inc. overflow counter
INTCON.TMR0IF = 0 ; // clear interrupt flag to enable next call on overflow
void Long2str(void)
unsigned char i, j ;
if(cntr == 0)
str[0] = '0' ;
str[1] = 0 ;
else
str[0] = 0 ;
i = 0 ;
while(cntr > 0)
for(j = i + 1 ; j > 0 ; j--)
str[j] = str[j - 1] ;
str[0] = cntr % 10 ;
str[0] += '0' ;
i++ ;
cntr /= 10 ;
while(*s)
Soft_Uart_Write(*s) ;
s++ ;
Thank you
char error;
void main( void)
T0CON = 11001000;
Delay_ms(2000);
do
Long2Str() ;
} while( 1);
if(INTCON3.INT2IF)
void Long2str(void)
if(cntr == 0)
str[0] = '0' ;
str[1] = 0 ;
else
str[0] = 0 ;
i = 0 ;
while(cntr > 0)
str[0] += '0' ;
i++ ;
cntr /= 10 ;
while(*s)
s++ ;
