PIC16F877A interfacing with hyperterminal.
sk8ter87
Member level 3
Malaysia
Hi guyz..it's me again..
i tried to do pic16F877A interfacing with hyperterminal.
but it does not work..:sad:
here i'm attaching the pic code..
hope you guyz can help me check the programming..
  • Phase_3_Hyperterminal.txt
Here is a sample program, which I tested as functional, make changes in your current code accordingly:
#include <16F84A.H>// Include header file
#fuses XT,NOWDT// Crysral Osc(4Mhz), No watchdog timer
#use delay(clock=4000000)// 4Mhz crystal frequency
#use rs232(baud=9600, xmit=PIN_A3, rcv=PIN_A2)// to set baud rate, Tx and Rx Pin
void main()
char scale;
 while(true)
   do
   printf("\n\rPress Y for YES or N for NO: ");
   scale = getc();// Wait until an character is recieved by RS232 terminal software
   scale = toupper(scale);// To convert lower case to upper case
   while ((scale!='Y')&&(scale!='N'));
 printf("\nCompleted");
Ohh....... I haven't used it..... :-(
Aren't you using serial communication(USART) module? Have you made the settings correctly i mean RX as input & TX as output of PORTC?
Regards,
Jerin. ;-)
Regards,
Jerin. ;-)
i alr done wif all then mention... can u check my codes if u dont mind?
