[PIC] PIC12F675 GPIO4 and GPIO5
eTechs
Newbie level 3
Dear All,
I am new to the PIC micro-controllers. I am using PIC12F675 and trying to toggle the GPIO5. I am using mikroC pro for PIC compiler and proteus7.4. I have tested my code on different version of mikroC and Proteus. I have tried with configuration register from 0x3FF0 to 0x3FF7. (enabling and disabling the oscillator in different modes) and still found the GPIO4 and GPIO5 in high impedance state. I used internal and external pull ups as well.
I need at least one adc channel and four IOs as output in 12F675 for my project.
Kindly give a hint/ code etc. to solve this problem.
Thanks.
eTechs
Project attached.
  • pintest.rar
Reactions: eTechs
    eTechs
@eTechs, @hexreader:
Do not forget to set ANSEL (and TRISIO) accordingly (zero if no analog input, or ... look at the datasheet).
@eTechs:
If you want four digital outputs then only one analog input is possible since GP3 is only a digital input (or MRCLR).
Config: INTOSCIO, WDT OFF, others as usual
Thanks to all. Actually I could not write to the port because I was not configuring correctly the micro-controller in the compiler (mikroC).
