rasp
Newbie level 2
I'm trying to connect a PIC16F877A to program it in MPLAB X IDE, but I'm getting an error about target device ID.
My breadboard: **broken link removed**
MPLAB X:
MPLAB X:
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.43.35
Firmware type..............Midrange
Programmer to target power is enabled - VDD = 5,000000 volts.
Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device.
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x7
Device Erased...
Programming...
program memory
Address: 0 Expected Value: 2803 Received Value: 0
Failed to program device
