nanorobot
Newbie level 6
Hi
Some pic microcontrollers (in my case pic16LF1503) - when MCLR is enabled - have MCLR pin internally connected to Vdd through a weak pull-up. My question is: Does it mean that I do not have to use external pull-up resistor to tie up MCLR pin to Vdd? I've been searching for a definite answer but I haven't found any. Some people say that if there is an internal pull-up, there is no need to use an external pull-up resistor and the MCLR pin can be left floating. Some people also say that even if there is an internal pull-up, it is recommended to use an external pull-up resistor (and they don't exactly say why). Thank you for any suggestions.
