[PIC] LCD VU Meter problem
Okada
Banned
I am making an LCD VU Meter. I am writinf 0xFF to get full block. I am doing this in a loop.
My bar graph length is 18. How can I write full blocks on 18 columns in one go ?
Also what values should I use to write sliced blocks on HD44780character LCD ?
See attached video. My bar character is like this. I am writing 0xFF to get this char. I also have 4 different sliced bar data but it uses arrays. How can I replace the array with just char values to get sliced bars for representing the fractional part ?
I am cleaning up the code. I will post the code in a few minutes.
Is the VU Meter working fine ? I am only updating the LCD data if there is a change.
  • Proteus Simulation Video - LCD VU Meter.rar
hello,
use CGRAM characteres !
i used this for Temperature horizontal **broken link removed**
the main problem is no acces to the 8th horizontal bit , so you have to play with Normal caractere 0xFF and additional CGRAM caracteres
see in my code ( even the display is in I2C mode!)
but with a graphic LCD display, result is better
example : Horizontal barre grpah with 96 pts
