Python
Newbie level 3
16c745
I'm totally new to pic programming, but understand the basics of converting a text file to an ASM file which is then used to compile a HEX file.
I've downloaded several hex files for use with a 16C745 Microchip PIC and built the hardware from the schematics provided by the author.. Ive now received a sample of the 18F2550, which according to the Microchip web site is a replacement compatible device for the 16C745, but with flash memory.. I must admit I looked at the data sheet and it is way over my head :?
I've downloaded the latest version of MPLAB that supports the 18F2550, and a Hex dis-assembler.. should I simply be able to change the include statement in the asm file to the new chip and then re-assemble the asm file ?? - this errors.. so I gather that somthing is different internally
Im using Winpic and an Olimex PG-02 programmer (JDM programmer) - but I'm just using MPLAB to compile the HEX first as this programmer is not supported under MPLAB.
Your guidance would be welcome
