marco antonio
Member level 3
anubis s dd
I have a doubt about the power supply as you know you may use a 100 w lamp to load the power supply and then check the voltages. I did so and the voltages were
correct, the HOT collector was disconected. But when I connect the collector again the voltage I get is 130 v instead of 95v and the tv doesnot work at all. My question is the power supply correct and the protection is working.
Please I will appreciatte your comments
rgds
marco
rgds
marco
