Phantom power for TV antenna amplifier
Thoma HAUC
Junior Member level 2
I need to design a circuit that will provide power to a TV antenna amplifier.
My constraints are :
* Characteristic impedance : 75 Ohm,
* Power supply for antenna amplifier : 24V @ 100mA and
* Available power supply : 9V @ 1.6A
I think I will base the solution on a step-up converter.
But I have a concern about the harmonics of the switching frequency.
Moreover, I do not know how to calculate the inductor and the capacitor (not the one of the step-up convert but the capacitor which blocks DC to TV and the inductor which blocks HF to the step-up converter).
Thanks in advance
Thoma
@ SLK001 :
It was my fear. But the original broken power supply was a switching mode power supply. Unfortunately, it is not longer available.
@ chuckey :
Does a 1nF ceramic capacitor do the job ?
Can I use a 150nH air inductor for this job ?
The 9V is a DC power supply so I can not use Cockroft-Walton voltage multiplier.
Thoma
Thanks in advance
Thoma
The larger the Henry value, the more it chokes AC. The required inductor value is not easy to calculate. This might be called a rough estimate... You want to block frequencies above 30 MHz. Suppose your converter has an impedance in the output of 240 ohms (24V / 100mA). A reasonable inductive impedance could be 10x that, or 240 ohms.
Therefore find the inductance L that satisfies the formula XL = 2 * Pi * f * L.
240 = 2 * Pi * 30MHz * L.
As for the capacitor value, it should be large enough so that it charges to a stable DC level and doesn't change much. The less AC current you have going back and forth, the smaller can be the C value. Again this is not easy to calculate. You probably need to experiment.
Hi BradtheRad,
When you say 10x, I suppose you mean 2400 ohms. This gives a 12.7µH inductor.
Thoma
Xl = 2 X PI X 500 X 10^6 X 150 X 10^-9 ~ 450 ohms, this is OK because the coax will have a Zo of 75 ohms and 450 is higher then it, 750 ohms would be better, i.e. 150 X 750/450 or 250 nH. 24V seems a high value for the amp feed, in the UK it is standardised at 12V. Have a look inside it to see if there is some form of voltage stabiliser you can bypass. You are only dealing with small amplitude signals <100 mV.
Frank
Hi BradtheRad,
Thoma
Yes, you're correct. My mistake. Anyway it's a crude calculation, based on whatever parameters we can draw on. It could be off by an order of magnitude.
