PCB layout error...node not found
rahul32
Newbie level 6
Newbie level 6
Mumbai
am using Protel 99SE for the first time and I have completed the schematic
diagram and created a PBC file with all the appropriate footprints.
The schematic ERC check is OK but when I 'Update PCB.' and press 'Preview
Changes' I get the following errors:
ERRORS: 40 macros can not be executed:
Macro 1: New Node
Add node led-2 to net NetR8_1
Error: Node not found
Macro 2: New Node
Add node d11-2, to net netR1_2
Macro 3: New Node
Add node d26-1 to net gnd
The errors are all Node not found.
In this only shows error for diode,zener diode & led.
& another all component placed perfectly..
so, what's the exactly problem i don't understand..?
why it's shows in only didode, zener diode & Led..?
