PCB Designing for filter and IC based circuits
manieceindia
Banned
Bangalore
Dear friends,
I'm beginner for PCB designing, kindly help me how to select values of resistor and capacitor in IC based and Filter based circuits
Regards,
Manivannan Selvaraj
In the beginning one can make PCB arbitrarily with or without application for practice.
In the course of all this one may come across what are
IC based circuits
and what are
and also their specifications. These specifications will dictate design.
Right now you are at PCB design. Work on that right from schematic trough netlist, component layout, manual and auto, routing etc till the final artwork, its printing, etching, masking, drilling etc.
Hope this helps !!!!
PCB deisgn have following steps broadly -
1) Analyze the functionality that you want to implement in the baord and select appropriate Chips and components
2) Development of schematic diagram ( Circuit that you want)
3) Then generate the netlist and import that netlist in to PCB routing editior
4) Route the complete circuit on the PC using PCB routing editor
5) then generate garber file and send that files to PCB manufactors
you will get the you PCB made....
I uses KiCAD for this ....as it is free....
Good Luck
Work on the sample PCB projects that come along with PCB design software package. For a PCB designer value of components does not make any difference. Only the footprint does... :)
Component values don't seem particularly related to PCB design. It's a question of filter circuit dimensioning and applies on a breadboard as well.
Dear friends,
Regards,
Manivannan Selvaraj
Go through this PDF it might give you an clear picture about PCB Designing.
  • pcb-rule.pdf
  • PCB Basics.pdf
I'm not getting any pdf.
---------- Post added at 05:42 ---------- Previous post was at 05:41 ----------
YES, I GOT....
