Parametric Sweep in CST MWS
ahsaan
Member level 5
Pakistan
Hello
My results of Parametric sweep are not saving....I have run Par. sweep from transient solver but the results are not being saved...
hello ahsaan,
go to transient solver >> and tick store results data in cache.
once simulation is over goto the simulation folder (should be same name as your CST file name) >> Result >> Cache >>and then you can see different folders with RUN 00XX.
Each folder got a seperate file for a parameter.
Hope it helps ..
Praful
    V
hi,
U should use MACRO - WIZARD - COMPARE MULTIPLE RUNS,
but be sure - as the other user posted - that you have stored
before all runs in cache, this is an option of the solver dialog
box.
    V
