knataraj
Newbie level 5
cadence parametric sweep
Hi
I am using Analog Artist Version 5 and tried to sweep a paramset in spectre.
I gave the paramset statement as follows
data paramset{
VDC T
0.20 0.6e-06
0.22 1e-06
swp sweep paramset = data
both VDC and T have been defined earlier.
When I simulate, I get an error like:
Internal error found in spectre during Sweep analysis 'swp'. Please run
'getSpectreFiles' or send the netlist, the spectre log file, the
behavioural model files , and any other information that can help
identify the problem to support@cadence.com.
Segmentaion fault.
Abort.
Also, Assuming I have variable Vdc to represent DC vltage and T representing time units, is there a method to specify these in a piecewise linear supply( I am getting a syntax error if I use these variables in a Vpwl source)
Whats wrong in what I am doing?
Any suggestion ASAP will be of great help.
Thanks!
Krishna
Hi
data paramset{
VDC T
0.20 0.6e-06
0.22 1e-06
Segmentaion fault.
Abort.
Thanks!
Krishna
