Hot Wire
12 parallel resistor calculator
Does anybody know where I can download the following calculator.
It calculates the two resistors in parallel given the final resistance value and the set require (e.g. E12)
1) I input the Resistance Value that I require.
2) I input the resistor set to be used E12
3) The calculator gives me the nearest two resistor values I require to put in parallel to obtain the required resistance (or as near as can be).
Thanks in advance.
Thanks in advance.
