Pads Logic and Copy as Bitmap
prd
Member level 3
Member level 3
Dear All,
I use Pads Logic to draw schematic, but I have problem to make documentation.
I want to copy schematic from Pads Logic using Copy as Bitmap command. But when I switch to MS word, the past button disable, so I can not paste the picture.
Please help suggest what wrong with me, or what I should do first to copy picture of schematic.
Thank and Best Regards,
Prd
Added after 5 minutes:
FYI:
I use Pads Logic 2004 SP2 on Windows XP and MS word 2003
prd
Select the Copy as Bitmap from the pull-down manual, and then select the area you want to copy.
I got no problem using Power Logic 4.0
    prd
Thanks trigger74 for your help :)
The PADS Logic help told me INCORRECTED step, it tell me to drag the cursor over the area to copy, and then choose Edit/Copy as Bitmap, which is not work.
