Does anybody know which methodology is better as per as performance is concern.?
Assuming that you are implementing a same testbench in vmm & ovm.
thanks
Anyway may be not significant but performance will be different if we test both methodologies in the same tool.
I don't know which one is better but OVM2.0.3 release is announcing performance improvements.
OVM is from Cadence/ModelSim and VMM is from Synopsys. So I'm pretty sure OVM will run faster on Cadence/ModelSim simulator than the Synopsys simulator, and vice versa.
