overlap and width DRC errors in Eagle CAD
electrophile
I'm a new Eagle user and I created an SOIC part with a small heat pad in the middle. The pad is on the bottom and at the top copper layers. The bottom pad is purely for soldering convenience sake. Its easy to solder the pad by heating the bottom pad with your soldering iron. Now, the board has 2 layers and the bottom one is all GND. I've attached an image here. The manufacturer says that I should extend the heat pad beyond the IC and put some vias so that heat is transferred to a larger plane. Now I've put these vias and named them GND but I keep getting an "Overlap" error. Why is this? Also all the copper pours are created with zero widths because it gave me better control over the fill and now I get "Width errors". How do I resolve these?
An overlap error is to be expected when you put vias in the power pads. As long as you are sure the layout is correct you can "approve" then so you don't get them again. I have a board with 117 "approved" errors and some with more than double that.
You don't need zero width to get a good fill and I think it can cause some problems in the Gerbers. Also, the width is used to create the thermals so a sensible size is better.
Keith
