pozzugno
Newbie level 3
I don't know if this is the correct forum section to post this question. Sorry if I'm wrong.
I want to use D-type flip-flop 74HCT74 as a trigger: when I open a switch, the output should change and should stay changed until a reset signal.
The switch is connected between ground and +24V through a pull-up resistor of 2700 ohm.
I don't want to increase the complexity of the clock input, because I'd like a propagation delay as low as possible.
I read on the datasheet from NXP the following note:
Can I connect the connect input of 74HCT74 to a pull-up resistor to +24V without any risk to damage the IC?
The current ratings are +/-25mA and I think I'm inside this limits with 2700 ohm and +24V.The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
