hiren.dave@bhuved.com
Banned
hi friends,
i am using picf4550 and handling 3 interrupt. my program is given below.
but i get the error given below.
Please direct me to solve this error....
#include<P18F4550.INC>
R1 EQU 0X10
R2 EQU 0X11
R3 EQU 0X12
R4 EQU 0X13
ORG 0000h
GOTO MAIN
ORG 0008h
BTFSS INTCON3,INT1IF
GOTO H1
GOTO HighInt
H1 BTFSS INTCON,INT0IF
RETFIE
GOTO LOWINT
ORG 0018h
BRA ANOTHER
MAIN
ORG 900h
SETF TRISB
CLRF PORTB
CLRF TRISD
CLRF PORTD
BSF TRISB,1 ;INT1 I/P PIN ENABLE
BSF TRISB,0
BSF TRISD,2
BSF INTCON, PEIE ; ENABLE PERIPHERAL INTERRUPT ENABALE
BSF INTCON,GIE
BCF INTCON3,INT1IF
BCF INTCON,INT0IF
BCF INTCON3,INT2IF
BSF INTCON3,INT1IE
BSF INTCON,INT0IE
BSF INTCON3,INT2IE
BSF INTCON2,INTEDG1
BSF INTCON2,INTEDG0
BSF INTCON3,INTEDG2
BSF INTCON2,RBPU
BCF INTCON3,INT2IP
MOVLW 0FH
MOVWF ADCON1
BSF RCON,IPEN
CLRF R1
CLRF R2
CLRF R3
h1
goto h1
HighInt:
ORG 800h
CLRF PORTD
MOVLW 02H
MOVWF PORTD
;CALL DELAY
;CLRF PORTD
BCF INTCON3,INT1IF
BCF PORTB,1
RETFIE
LOWINT
ORG 700h
MOVLW 04H
MOVWF PORTD
BCF INTCON,INT0IF
BCF PORTB,0
RETFIE
ANOTHER
ORG 600h
MOVLW 01H
MOVWF PORTD
BCF INTCON3,INT2IF
BCF PORTB,2
RETFIE
END
Debug build of project `C:\Documents and Settings\Bhuved\Desktop\HIREN DAVE\pic\programs\F 45 programs\3 INPUT INT\3 INPUT INT.mcp' started.
Language tool versions: mpasmwin.exe v5.42, mplink.exe v4.40, mcc18.exe v3.40, mplib.exe v4.40
Preprocessor symbol `__DEBUG' is defined.
Thu May 10 16:56:35 2012
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\Bhuved\Desktop\HIREN DAVE\pic\programs\F 45 programs\3 INPUT INT\3 INPUT INT.o".
Clean: Deleted file "C:\Documents and Settings\Bhuved\Desktop\HIREN DAVE\pic\programs\F 45 programs\3 INPUT INT\3 INPUT INT.err".
Clean: Deleted file "C:\Documents and Settings\Bhuved\Desktop\HIREN DAVE\pic\programs\F 45 programs\3 INPUT INT\3 INPUT INT.lst".
Clean: Done.
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\mpasm\mpasmwin.exe" /q /p18F4550 "3 INPUT INT.ASM" /l"3 INPUT INT.lst" /e"3 INPUT INT.err" /o"3 INPUT INT.o" /d__DEBUG=1
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 10 : Found directive in column 1. (ORG)
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 13 : Found directive in column 1. (ORG)
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 25 : Found directive in column 1. (ORG)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 26 : Found opcode in column 1. (BRA)
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 32 : Found directive in column 1. (ORG)
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 77 : Found directive in column 1. (ORG)
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 91 : Found directive in column 1. (ORG)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 93 : Found opcode in column 1. (MOVLW)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 94 : Found opcode in column 1. (MOVWF)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 95 : Found opcode in column 1. (BCF)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 96 : Found opcode in column 1. (BCF)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 97 : Found opcode in column 1. (RETFIE)
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 102 : Found directive in column 1. (ORG)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 104 : Found opcode in column 1. (MOVLW)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 105 : Found opcode in column 1. (MOVWF)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 106 : Found opcode in column 1. (BCF)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 107 : Found opcode in column 1. (BCF)
Warning[203] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 108 : Found opcode in column 1. (RETFIE)
Warning[205] C:\DOCUMENTS AND SETTINGS\BHUVED\DESKTOP\HIREN DAVE\PIC\PROGRAMS\F 45 PROGRAMS\3 INPUT INT\3 INPUT INT.ASM 112 : Found directive in column 1. (END)
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\bin\mplink.exe" /p18F4550 /l"C:\Program Files\Microchip\mplabc18\v3.40\lib" "..\..\..\..\..\..\..\..\MCC18\bin\LKR\18f4550_g.lkr" "3 INPUT INT.o" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"3 INPUT INT.cof" /M"3 INPUT INT.map" /W
MPLINK 4.40, Linker
Device Database Version 1.3
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - section '.org_2' can not fit the absolute section. Section '.org_2' start=0x00000018, length=0x00000002
Errors : 1
Link step failed.
Debug build of project `C:\Documents and Settings\Bhuved\Desktop\HIREN DAVE\pic\programs\F 45 programs\3 INPUT INT\3 INPUT INT.mcp' failed.
Thu May 10 16:56:37 2012
BUILD FAILED
