JonathanRalph
Newbie level 6
Good day
I would like to isolate the control side of the circuit from the power side by using an optocoupler. As shown in the picture below, I connected the anode of the scr to the collector of the optocoupler bjt and then connected the emitter to the gate (with a resistor and a schottky diode in between). But I'm worried that the optocoupler may not withstand 220Vrms. I looked at the 4N25 datasheet and found that the collector-emitter breakdown voltage of the optocoupler bjt is only 70V.
From the schematic, is there a proper way of interfacing the optocoupler to the SCR circuit to trigger the SCR properly without damaging the opto?
Specs:
Bridge rectifer: 1000V 35A
SCR: 600V 30A
Control side of the circuit is not shown for simplicity. It is assumed to be correct and working.
Specs:
SCR: 600V 30A
