HankMcSpank
Newbie level 3
5V Opamp connecting to a higher voltage power amp?
I've a small preamplifier, which has an opamp powered at +/- 5V supply.....the output of this opamp feed into an power amplifier powered at 18V
The input pin of the power amplifier is biased at 1/2 VCC ....9V.
The output of my opamp is biased at 0V ...so I need aDC blocking cap between.
What I'm worried about is at power up, the input to the power amplifier is going to slew up quickly to 9V DC bias - will this power up voltage will feed back through the blocking cap and zap my opamp output stage?
Is there a way of protecting against this power up voltage spike?
