op amp stability question
KonstanU
Member level 5
Bayreuth, Germany
I know when amplifier is unstable. But I have got the next picture of amplifier loop gain (FB is open).
So is this picture stable or not?
As far as I can see (the picture is very hard to read) - the phase reaches 0 deg for a loop gain magnitude>0.
Thus, after closing the loop the circuit will be unstable.
Thank you.
Lets I make picture more readable.
I have non-inverting amplifier and I apply AC signal on the non-inverting input of op amp.
On the picture I have indicated three frequencies at which loop gain passes through G=1.
f1 = 6.5 Mhz (PM = 100)
f2 = 9 Mhz (PM = 160)
f3 = 18 Mhz (PM = 50)
It looks like stable but I have doubts.
Application of amplifier is a bite strange.
It is used as the Gate Driver with adjusted voltage.
I have connection of OpAmp and current boost stage.
In practice I have oscillation and I think that the reason for that could be multi-poles system.
In practice, small signal analysis doesn't describe the system behaviour completely. The most severe point is the class B current boost stage where both MOSFETs are off for the calculated bias point. In addition MOSFET and IGBT capacitances are strongly voltage dependent. The OP might add non-linear behaviour.
As far as linearity can be assumed, bode diagram stability analysis should still work for the present circuit. I wonder however where the "dip" around 10 MHz can be localized in the circuit.
Hi FVM,
Wont it be the self resonating frequency of the inductors use
I have checked simulation model.
I can state that induction is not the reason of unstability.
I have simplifed my load and what I have got you can see on the following pictures.
Results reveal that external current boost creates additional poles and zeros that make system unstable.
The question is if the non-feedback current booster in the second circuit is meeting your design specifications?
In addition to my previous post, I see that you biased the class B buffer by a DC input voltage and a load resistor in your simulation circuit. This point can't be guessed from your previous posts. If the setup gives a realistic representation of the real load situation is a different question.
I also notice that Ra and Rb have considerable high values, thus MOSFET capacitances matter a lot.
