sharkies
Member level 5
Hi guys,,
what's the usual mos decoupling unit cap size you use for your onchip power decoupling?
I understand that depending on the W/L size, gate resistance changes and there's an optimum size to de-Q inductance ringing. I'm in a real crunch and unfortunately don't have time to think through all that.
what W/L sizes do you usually use for your unit cap before you instantiate an array of them?
Currently the design is working on the order of ~hundred MHz. (under 500MHz)
I'm using High voltage mos to minimize leakage. It seems like I have a LOT of extra space to fill in with decoupling.
Thanks, as always
Thanks, as always
