analog_ambi
Member level 1
On chip balun for single ended to diff
Today at 12:14pm Quote Modify
I am using a balun to convert single ended signal (from signal generator) to differential (onchip).
1. Is it necessary to ground the center tap of secondary? I am AC coupling the differential.
2. Since sig gen has 50 ohm impedance i have put a 50 ohm in parallel with primary.
