justkelly
Newbie level 1
So I saw an old B&K 1460 at Goodwill and on impulse picked it up. It powers up all right, and I was able to start the initial starting procedure in the manual, but I'm having trouble vertically adjusting the trace. It's dropped down past the bottom of the CRT; I can see a glow coming from down there if I turn the intensity up, basically a vertical band of "glow".
I can adjust the band easily using horizontal adjust, but vertical adjust shows no visible change. Stability, Focus, etc no change either. When I power off the scope, I can see the trace "hop" up to roughly the center of the screen as the CRT fades, and if I turn it back on again quickly it shows up again, only to dive back down below where I can see it. So it's pushing a trace, I just can't get to it.
I had the lid off, and everything looks basically OK--no burnt-out wires or anything like that. The pot for vertical adjustment is all wired up as far as I can trace. Any suggestions as to what it might be would be welcome, as this is a nice ol' piece of kit, and I would love to get it up and running properly again. TIA!
