Off the Shelf Current Source for 0-40mA Requirement
AzharElectronics
Junior Member level 2
Hi All,
I need to Test Sensor Signal Conditioning Circuit for same I need a Current source from 0-40mA, In order to claim Functional Tests I need a off the shelf current source so that the calibration and accuracy is marinated from that off the shelf current source. Any thing which is around USD 60-100 would be good. Not very expensive source.
I got this option but not sure If I can use same: SE-408
Thank You.
we don´t know either. How can we? Only you know the requirements.
I can only recommend to compare your requirements with the given specifications.
Klaus
1) Resolution ?
2) Accuracy ?
3) Compliance (range of V the current source has to operate in)
4) Control, and need for triggering source or just a pot ?
5) Any special environmental conditions for operation ?
Regards, Dana.
