Odd message on computer
ljcox
Full Member level 5
Melbourne Australia
Some weeks ago, my granddaughter used my computer to download podcast onto my ipod
since then whenever I start my computer, I see the following error message.
Applesync.exe entry point not found
The message reads ' the procedure entry point XMLTEXTREADERCONST Name could not be located in the dynamic link library
File Number LIBXML2.DLL
Does anyone know how I can stop this happening?
Any assistance would be appreciated
It sounds like you now have some (incomplete) Apple software on your PC. Look under the 'installed programs' in Control Panel to see if you can see it and uninstall it. Alternatively, look in the Startup folder to see what is running on startup and remove it there. You have to look in all 3 startup folders - under your username, default user and all users.
Another way to track it down is to search for the KEY called RUN in the registry and see what is running at startup.
Finally, if it is actually a SERVICE then you need to use 'administrative tools' 'services' to track it down and stop it running.
I hope that helps. I am not a PC expert so hopefully someone else will have a better solution.
Keith
