OCR detection in hundreds of PDFs
Basil
Member level 5
I have hundred (even thousands) of PDFs; I need to know which have OCR already made in order to be sure any index I'd make will include all PDFs.
¿How do you do a list of PDFs lacking OCR in order to add them OCR later?
OCR is usually a text doccument or a word file. The ones still in PDF are not in OCR form. Maybe i didn't understand your question but one tip is the Google Docs has a feature of OCR, just tick the box that says "Convert text from PDF or image files to Google Docs documents".
Thanks for you reply
After some web searching I was able to make listings of PDF with an without OCR (or whatever you name it) embedded.
