FrustratedEngineer
Newbie level 6
I am working on PIC18F45K40. I am using Internal EEP as Data memory. My task is to Read/Write Data on EEP.
Here is a source code...
Main routine
Sub routines
when I check the output of the main routine in debug mode, I always get 0xFF in the array.
Please tell me where is it going wrong.
Note -
1. I have already browsed through google/microchip website for the sample code of this MCU but didn't get any.
2. The MCC generated code and the code I wrote matches fairly.
Main routine
volatile U8 au8Data[5]= {0x01, 0x02, 0x05, 0x07, 0x08};
volatile U8 u8Index;
WriteData(&au8Data[0], 10, 5);
ReadData(&au8Data[0], 10, 5);
//Deliberately added to check variable value in debug mode
for(u8Index=0; u8Index < 5; u8Index++)
au8Data[u8Index] = 0x00;
Sub routines
void WriteData(U8* Pu8Src, U8 u8Area, U8 u8Len)
U8 u8Index;
if( (Pu8Src != NULL)&&(u8Len > 0))
for(u8Index=0; u8Index < u8Len; u8Index++)
WriteByte((u8Area+u8Index), Pu8Src[u8Index]);
void ReadData(U8* Pu8Dest, U8 u8Area, U8 u8Len)
U8 u8Index;
if( (Pu8Dest != NULL)&&(u8Len > 0))
Pu8Dest[u8Index] = ReadByte(u8Area+u8Index);
* OnChip EEPROM SFRs
#define D_CPU_EEP_REG_ADDR_LOW NVMADRL
#define D_CPU_EEP_REG_ADDR_HIGH NVMADR
#define D_CPU_EEP_REG_DATA_LOW NVMDAT
#define D_CPU_EEP_BIT_EN_WR NVMCON1bits.WR
#define D_CPU_EEP_BIT_STATUS_WR NVMCON1bits.WREN
#define D_CPU_EEP_BIT_STATUS_RD NVMCON1bits.RD
#define D_CPU_EEP_SET_MEM_AS_DATA() {\
NVMCON1bits.NVMREG0 = 0;\
NVMCON1bits.NVMREG1 = 0;\
#define D_CPU_EEP_UNLOCK_SEQUENCE() {\
NVMCON2 = 0x55;\
NVMCON2 = 0xAA;\
void WriteByte(U8 u8Address, U8 u8Byte)
U8 u8IntrReg = INTCONbits.GIE;
D_CPU_EEP_SET_MEM_AS_DATA();
D_CPU_EEP_REG_ADDR_LOW = u8Address;
D_CPU_EEP_REG_ADDR_HIGH = 0xFF;
D_CPU_EEP_REG_DATA_LOW = u8Byte;
D_CPU_EEP_BIT_EN_WR = D_BIT_HIGH;
D_CPU_DISABLE_INT();
D_CPU_EEP_UNLOCK_SEQUENCE();
D_CPU_EEP_BIT_STATUS_WR = D_BIT_HIGH;
while(D_BIT_HIGH == D_CPU_EEP_BIT_EN_WR)
//Wait for Writing to be finished
// D_CPU_ENABLE_INT();
INTCONbits.GIE = u8IntrReg;
D_CPU_EEP_BIT_STATUS_WR = D_BIT_LOW;
///Assembly code from Datasheet
; Data Memory Address to write
BCF NVMCON1, NVMREG0 ; Setup Data EEPROM access
BCF NVMCON1, NVMREG1 ; Setup Data EEPROM access
MOVF EE_ADDRL, W ;
MOVWF NVMADRL ; Setup Address low byte
MOVF EE_ADDRH, W ;
MOVWF NVMADRH ; Setup Address high byte (if applicable)
; Data Memory Value to write
MOVF EE_DATA, W ;
MOVWF NVMDAT ;
; Enable writes
BSF NVMCON1, WREN ;
; Disable interrupts
BCF INTCON, GIE ;
; Required unlock sequence
MOVLW 55h ;
MOVWF NVMCON2 ;
MOVLW AAh ;
MOVWF NVMCON2 ;
; Set WR bit to begin write
BSF NVMCON1, WR ;
; Wait for write to complete
BTFSC NVMCON1, WR
BRA $-2
; Enable INT
BSF INTCON, GIE ;
; Disable writes
BCF NVMCON1, WREN ;
U8 ReadByte(U8 u8Address)
U8 u8Byte;
D_CPU_EEP_BIT_STATUS_RD = D_BIT_HIGH;
NOP();
NOP();
u8Byte = D_CPU_EEP_REG_DATA_LOW;
return u8Byte;
BCF NVMCON1, NVMREG0 ; Setup Data EEPROM Access
BCF NVMCON1, NVMREG1 ; Setup Data EEPROM Access
MOVF EE_ADDRL, W ;
MOVF EE_ADDRH, W ;
BSF NVMCON1, RD ; Issue EE Read
MOVF NVMDAT, W ; W = EE_DATA
Note -
