d123
Advanced Member level 5
I have a cat-flap (not currently in use, and I may not get to use it again for quite some time, so this is hardly urgent) activated by the identity microchip, it has a sensor so only the "registered" cats can come in. Otherwise you get food raid visits or nap stops by passing cats, or worse, which I do not want, so not interested in using a normal one.
The cat-flap is so noisy opening from outside it would scare me with my head underneath it, sounds like a guillotine (even the user manual says some cats may be scared by the noise - it's so loud anyone would be scared). We used it in one house where I could change the door and install the cat-flap, she'd go out but never came in through it, she tried a few times then gave up.
I think it is a solenoid that activates the latch by the sound of it, one day I would like to change this, if it doesn't mean destroying the cat-flap in the process.
Somebody suggested using a cassette motor some time ago, not sure this would work if the actual latch is a solenoid. Any suggestions for silencing this awful thing or replacing the solenoid with a less cat-unfriendly device?
