Nextion hex to Nextion LCD
radium98
Full Member level 2
leb
hello freinds .
can you lead me to a way to try to convert transfer a hex file to nextion lcd .
i can see many have done it but i coul not find a way to figure it out ,any ints tips thanks .
the hex is public for a transmittar fm that work with push buttom i need to transfer it to touch screen .i see someone has done it before i have only a picture of that project .
you must give still more detailed description of the requirement.
-what is 'convert transfer a hex file'?
-is the hex file is for nextion?
-a push button input to be transferred to touch screen?
the hex is in the pic 16f84a or 16f628a , so how is that done with two tx and rx cables ? i dont understand while the hex is still in the pic
if the nextion hex is within pic then you must transfer them through a serial(uart) port .
hi thanks for the reply ,but i think you mis understood me or i cannot transfer right my question,and i am a noob in this kind of screen type TFT,i only know the use of lcd
i build before the same transmitter with same characters but on an lcd 16 x 2 lines ,when i saw someone transfer the same things but to this nextion tft and as i see he can control it too ,my question is how ?if possible to explain to me ,maybe i can try to do it my self once upgrading my transmitter from puch buttom up down and set frequency to tft fucntion on screen :)
regards
I understand that you have 16x2 lcd now.
You want to replace it with nextion touch type.
For that you must rewrite your original display routine for the touch type and in the nextion format.
a complete rewrite is necessary.
