tuk
Junior Member level 1
Hi, have just purchased a Tektronix 2215A from ebay ...and need to buy 2 probes to make sure its functioning properly when it arrives....& I'l be using the scope for learning and tinkering with small micro-controller projects and other pcb stuff..so any advice or conformations would be appreciated as I have to buy something today/tomorrow
I have made a small table with scope specs ...and 4 different probes ..would I be right in thinking the Top Quality 100MHz Oscilloscope Scope Probe is better than the rest..in every area?
![PROBES.jpg PROBES.jpg](https://www.edaboard.com/data/attachments/7/7977-a96064e183504e62cc900e14280c7d37.jpg)
here are my assumptions of preferable probe characteristics:
bandwidth :: higher than scope
input resistance :: lower than scope
input capacitance :: lower than scope
compensation range :: must include the scope's cap value ..& wider range is better than narrow
rise time :: lower than or equal to scope
working voltage :: higher than scope...or at least higher than voltage levels I expect to be working with
