[SOLVED] Neural Network with Matlab in FPGA Spartan 3E, ADC Problem
Allahyarzadeh
Iran,Tehran
Hi, thanks in advance
I want to implement a trained Neural Netw in Fpga(Spartan 3E), I know it's not the first time but my question lies in hardware level.
you know to train a Neural netw I need some sample data Input,but the system after implementing is going to use the out put of ADC of board as the neural network Input( :?: )
I use MATLAB neural network toolbox's pattern recognition tool ( nprtool ) which is a wizard like tool to train the neural network.(No I don't use command line to train network)
the problem is the output of ADC is unknown to me,the board use a LTC1407 ADC which is a Serial 12-Bit, 3Msps ADC with Two Simultaneous Differential Inputs and has two channel Inputs and 1.5Msps Throughput per Channel,and SPI output(serial).so I should some how model this kind of converting in matlab to train my network with the exact output of adc.
I've trained my Neural network with 4096 point fft wave data like output of adc(input of network),but it didn't work.
so how I should train my network to fit its input when it's implemented ?
if my question is unclear let me know:smile:
