need to make a dual supply from a single supply
desperado1
Full Member level 3
dual supply from single supply
I have a single power supply of 15V. I need a +15V, -15V and ground terminal from that very power supply to operate the operational amplifier. Is it possible to make from it or require another configuration ?
single supply to dual supply
Yes it is possible. Some questions first:
-How many accessible terminals are there in the power transformer secondary winding?
-What is the current capability of the existing power supply?
-What is the current consumption of the intended circuit?
-Is the operational amplifier to be fed with ±15 V or can work with ±5V ?
-Do you have a second identical power supply?
-ive supply from positive supply using 555
You can use a buck-boost regulator. As an example, the LM5118 from National.
Another example is the LT3483 from Linear Technology https://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,C1033,P8151
Or you can use a 555 a transistor and an iductor and build an inverting switcher, that produces say -18 to -20V. then use a linear regulator to bring that down to -15V.
single supply dual supply
if you only need to supply a few opamps and you need currents up to 150mA there is a simple solution : ICL7660 , it can output -3... -12V related to its configuration using a positive input.here is the datasheet:
also you can use a 555 IC and some diodes and capacitors to build a negative supply using positive inputs. just google it (555 negative supply) to find bunch of schematic for it.:D:D
555 negative supply
can u suggest me the simplest negative supply using 555 timer coz most of the schematics that i searched are a bit too complex for me.
single to dual supply ic 15v
pls use the negative voltage generator
+-5v sual supply schematic single positive
if you had searched the aforementioned keywords you must had found a bunch of sites for the problem. anyway here are some of the sites i found for negative supply using a 555 ic.in fact they are simple smps ,i am saying again that these are low current output supplies for cases like negative rail of a few opamps and etc:
http://freecircuitdiagram.com/2008/...-negative-supply-from-single-positive-supply/
http://www.csgnetwork.com/ne555c1.html
hope to solve your problem.
    desperado1
