need ideas for case study progect-logic circuits and design
teqno
Newbie level 2
Newbie level 2
durban
logic circuits
hy guys im only doing 1st year and i need ideas on what to create for my case study progect:?: based on logic circuits and design it with combination of more than one gate........besides an alarm!!!!!!!!!!!!!
logic circuits
door lock with alarm
counter
can you use other gates
    teqno
Re: logic circuits
Fast current limiter for power applications.
    teqno
logic circuits
i think counter is good.
    teqno
sorry teqno for not replying fast
i don't know what do u want in ur project , and what is in ur mind but i also just finished 1st year , and counter was one of the in-study projects that we take,
a counter is a very simple cct ,
its i/p is a pulse and its o/p is a no. on LED 7-seg display
i don't know what is ur info about the chips , so forgive me if i added unnecessary info.
u will need counter chip 7490,
its i/p is a pulse on the i/p pin and its o/p is BCD value on four o/p pins , it starts with zero and increase with every pulse to a certain BCD no u configure,
then u will need 7447 or 7448 (BCD to 7-seg decoder) , and a 7-seg display common anode,or common cathode (depends on the decoder)
    teqno
Re: need ideas for case study progect-logic circuits and des
you could also do some case study in modifying JK Flip Flop and form them into a T FlipFlop or Adding latches to eliminate indeterminate states.
here is the data sheets, read the pin configuration and truth table carefully to avoid unnecessary mistakes,
u can find also the cct and wiring on the web.
Dear Friend,
do not upload files that is available online for free.
fe el bedaya asf ya Aya 3la el files
well teqno , i think all what u need about the inputs and outputs of the counter chip will be explained in the data sheet , and u told me that u want to know about counter i/p and o/p, so i will try also to explain,
it simply (counts) the no. of pulses applied to the i/p pin , and gives the number of them as a BCD (binary coded decimal) on the o/p bins , BCD is a 4-bit code so it need four pins , for example
i/p_____________ o/p
i/p pin ______ q3 q2 q1 q0
0 pulse______ 0 0 0 0 _____ dec 0
1st pulse_____0 0 0 1 _____ dec 1
2nd pulse____0 0 1 0 _____ dec 2
3rd pulse____0 0 1 1 _____ dec 3
and so on , until it reaches (1001) (decimal 9) and it start from beginning , u can buy it form a shop that sells electronic components specially one that sells 74xx logic chips , so ask ur colleagues about a shop like that , or just ask friends that r older than u in college , i hope that helped.
Re: logic circuits
why dont you try www.twitter.com/VEATechs.discuss and get your answer
