nickip_22
We need to use synchronous TDM and combine 20 digital sources, each of 100 Kbps. Each output slot carries 1 bit from each digital source, but one extra but is added to each from for synchronization. Answer the following questions:
a. What is the size of an output from in bits?
b. What is the output frame rate?
c. What is the duration of an output frame?
d. What is the output data rate?
e. What is the efficiency of the system (ratio of useful bits to the total bits).
This is an example for an exam i have coming up and i don't understand how to do this.
Added after 3 minutes:
Also......
Repeat from above if each output slot carries 2 bits from each source.
Also......
