SKS
Junior Member level 3
hi,
I wanted to know whether channelizers are included in SDR for base station applications only..or are they also employed in terminal user SDR.
If yes, then why there is a need for channelizer in a terminal user equipment. We can directly use Digital Down Converter followed by a filter and a SRC to get back our baseband signal.
Also channelizers using QMF tree will give as output a number of channels at the desired stage of the tree. One has to know about 1) what stage of the tree to look for to get the desired bandwidth and also 2)Which one of the channels to down-convert form a particular stage to get the desired signal. So there seems to be greater complexity using channelizers for a terminal user..
Please correct me if I am wrong ....plz help me out....
Thanx in advance ....
