unbuildpain
Full Member level 2
I have a mouse which used to show around 10-15 colors, since 2 years or so, it has stopped showing all these colors and is only showing few colors. So today I decided to repair it, and I opened it up, it has two LEDs on it's PCB, these two LEDs display more than one color, one of these LEDs wasn't showing some colors, so I pressed on it and it showed the same color as the other LED but still weren't showing the amount of colors as it showed earlier.
I decided there wasn't much to do, so I put it back and as I was tightening screws, it completely stopped showing colors, the mouse is working fine but not showing any colors, inside the upper shell, there was a metallic block for weight I think, as the screws tighten, the metallic block presses on the LEDs and it must have done something. So I opened it up again and both the LEDs are not lighting up.
Is there anything I can do to repair this? Do shops sell LEDs which show multiple colors, will just replacing the LEDs resolve the problem?
