adaw
Newbie level 2
Dear gyus,
I am working on transmission device and I need to understand the transmission procedure.
The device include a primal sub-device where the message to be send must be taped and terminal sub-device where the taped message will be displayed.
When I taped the message 012 I observed the following transmitted message
1B244C5954454300410005410F0A0F0A5A63
1B244C5954454300410005512F01000138D3
1B244C595445430041002452000001000000000000000000000000000000000000000000000000000000000000000001D6
1B244C59544543004100245200010100000000000000000000000000000000000000000000000000000000000000009DF3
1B244C595445430041002452000201000000000000000000000000000000000000000000000000000000000000000029BD
1B244C5954454300410024520003010000000000000000000000000000000000000000000000000000000000000000B598
1B244C5954454300410024520004010000000101010100000000000000010100000000000001010101010000000000E2D2
1B244C595445430041002452000501000001000000000100000000010100010000000000010000000000010000000008D8
1B244C5954454300410024520006010000010000000001000000000000000100000000000100000000000100000000573A
1B244C59544543004100245200070100000100000000010000000000000001000000000000000000000001000000001356
1B244C5954454300410024520008010000010000000001000000000000000100000000000000000000010000000000B993
1B244C59544543004100245200090100000100000000010000000000000001000000000000000001010000000000009FA4
1B244C595445430041002452000A0100000100000000010000000000000001000000000000000100000000000000003F7B
1B244C595445430041002452000B0100000100000000010000000000000001000000000000010000000000000000002738
1B244C595445430041002452000C010000010000000001000000000000000100000000000100000000000100000000DEFD
1B244C595445430041002452000D0100000001010101000000000001010101010101000001010101010101000000003B56
1B244C595445430041002452000E010000000000000000000000000000000000000000000000000000000000000000D8C7
1B244C595445430041002452000F01000000000000000000000000000000000000000000000000000000000000000044E2
1B244C595445430041000843505111120503103CAF
1B244C5954454300410104520FF30100120500FE0000235900000000240500FE00002359000000009A0500FE00002359000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000005C60
When I taped the message ALP her is what is sent in the device
1B244C59544543004100245200040100000000000000000000000000000000000000000000000000000000000000005100
1B244C5954454300410024520005010000000101010000000000010101010100000000000001010101010100000000469D
1B244C59544543004100245200060100000000010100000000000000010000000000000000000100000000010000000B11
1B244C5954454300410024520007010000000100000100000000000001000000000000000000010000000001000000FA41
1B244C5954454300410024520008010000000100000100000000000001000000000000000000010000000001000000BF75
1B244C59544543004100245200090100000001000001000000000000010000000000000000000100000000010000002350
1B244C595445430041002452000A010000010101010101000000000001000000000100000000010101010100000000F7D1
1B244C595445430041002452000B01000001000000000100000000000100000000010000000001000000000000000016C2
1B244C595445430041002452000C01000100000000000001000000000100000000010000000001000000000000000007DB
1B244C595445430041002452000D0101010100000000010101000101010101010101000000010101010100000000003801
1B244C595445430041000843011813100501108322
1B244C5954454300410104520FF30100000500FE0000235900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000D14B
1B244C59544543004100055121010101A9B8
In each of these two messages, the first and last three lines are concerned with the addressing protocol, the message actually is from the second to the 16th line. In each of these lines, the first 28 characters are in Hex and are again concerned with addressing, the next 70 ones are binary and form the message while the last four are in Hex and are the generated code for that line.
I tryed all possible combinations for CRC16 and none has worked. Can any one help me to know how the code is generated ?
Thanks in advance![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance
