Need CPortLib for Borland C++ Builder6
ha
Junior Member level 1
IRAQ
Hi
I need CPortLib for Borland C++ Builder , anybody can help me ?
Best regards
Hi andre_teprom ,
Thnks for reply , but it is not working in Borland c++ builder 6 and i can not install package , there was an error.
As mentioned above, the suggested API is inherent to Windows, so that you don´t need install any package. It is a solution much more suitable to work, due it is not dependent of external DLLs which can stay no more compatible with further OS versions.
That´s the Microsoft developers support webpage:
Sorry, I´m not able to help much beyond that.
not working!!
No idea what should be the specific reason. Are you sure to open an existing COM port that is displayed in the device manager under serial ports?
Which handle value do you receive when calling CreateFile()? You also need to perform SetCommState and possible set CommTimeouts.
Code C - [expand]
8
hPort = CreateFile (lpszPortName, // Pointer to the name of the port
                      GENERIC_READ | GENERIC_WRITE,
                                    // Access (read-write) mode
                      0,            // Share mode
                      NULL,         // Pointer to the security attribute
                      OPEN_EXISTING,// How to open the serial port
                      0,            // Port attributes
                      NULL);        // Handle to port with attribute to copy
P.S.: What do you mean with country area related problems? Is it that the filename is expected in a 16-Bit charset?
you can see the image
I meant i can not open the URL
You said it. Sorry, I didn't read your post thoroughly.
So returning to your question, like andre_teprom I was always using native Windows API for accessing COM ports.
I presume, documentation of the basic Windows communication function should be available from other resources than msdn, it's also in the Borland help.
